Zabbix trigger string with time duration
  • Vicky
    • Jun 2018
    I wanted to enable trigger string with time duration, suppose if string "example" is there for more than 5 minutes but less than 10 minutes it shows high and if string "example" is there for more than 10 minutes but less than 20 minutes it shows disaster.
  • aigars.kadikis
    • Mar 2018
    • 208
    Am I correctly understand?:
    High trigger) 5m < STRING < 10m
    Disaster trigger) 10m < STRING < 20m
    and after 20 minutes the problem disappears?
    Are we talking about log file monitoring?
    Regards,
    • Vicky
      • Jun 2018
      We need to monitor logs from riemann database.
      requirement is like :-
      Warning trigger) after 5 minute and before 10 minute
      Average trigger) after 10 minute and before 15 minute
      High trigger) after 15 minute and before 20 minute
      Disaster trigger) after 20 minute
      and want to monitor string "soft"
      • kernbug
        • Feb 2013
        • 329
        Could you describe log file structure and update process? It's continuously written? Or can be rewritten if errors dissapear?
        • Vicky
          • Jun 2018
          Its something like for warning
          {Template New Server:some.new[{#SERVERID},status].str(soft)}=1
          log structure
          soft
          hard
          reboot
          error
          Also i am using trapper
          • kernbug
            • Feb 2013
            • 329
            Use Hysteresis https://www.zabbix.com/documentation...ers/expression
            https://blog.zabbix.com/no-more-flap...mart-way/1488/
